Low Power - 101,791 transmits, single cell
Several years ago I built a low power end device using the @ch2i arduino pro mini based design. I snapped in a LiFeP04 cell as it shipped from China, never charged.
It has reported BMP280 values every 15 minutes totalling almost 102,000 transmits before the single cell dropped below 3.0v today. I really wanted to keep this stacking up the frame counter but with a change to V3 stack in the near future I thought a new cell would be no harm!
Quite an impressive low power result and I would suggest with the smallest of solar harvesting circuits would have been a deploy for life device?
101791_transmits
Did you estimate the consumed energy for these more than 100k transmissions? It would be interesting what the capacity of the battery is, which txpower, SF and data-lenght you use.
@wolfp I did some power measurements back when I built the end node and quiescent current during sleep was so small I couldn’t reliably measure with any instruments I own (I am not kitted out with specialist uCurrent type low burden voltage instruments!).
I can tell you that the device sleeps for 15 minutes, polls the BMP280 (I think this may have a sleep mode but would have to look at the library, I don’t know for sure), math-adjusts floats, bit-shifts the result and sends this as a packet. It is always 19bytes of data with the same TX time which is short on SF7.
I have attached some metadata from the application end and traffic data from the gateway belwo:
META
PACKET
Garry
I agree, it is not easy to measure pulsing and fast changing currents with peaks in the uA-region. Therefore I think of measuring the discharge of a known capacity. The used energy could be calculated by the voltage- decrease after a known number of transmissions.
If you made 100k transmission and know the capacity of the battery, you can make a first estimation.
Fill a biggish quality capacitor and see how long it runs …
Actually when the battery was delivered in the post I started the device, never capacity tested the cell at all. It ran for about 4 months before I reset the frame counter and then it ran for approximately three years non-stop. Originally I expected to see the voltage drop quite quickly as I had not cycled or charged the cell. The experiment lasting 3+ years in my kitchen was not planned at all.
I have to praise @Charles, it is a clone of his low power design using his PCB interface and used his instructions to delete the LDO and any LED’s from the Arduino. Small things make a difference in something this frugal with power!
The starting voltage in the LiFeP04 18650 sized cell was 3.3v. Only yesterday I noticed it had reached 2.9v so I would suggest that this was no more than 45-60% of the cell’s full capacity in fact and that the actual number of transmits was probably 110,000 at least.
@descartes I would suggest a power micro-harvesting system of some sort with a small super cap would be a deploy for life setup also. This device cycles 96 times per day and wakes spike power/current use but a small solar/super-cap device reporting a digital trigger/wake-interrupt per day or per week/month would be a no-brainer I would guess?
Garry
I was referring to a method of power consumption measurement.
It looks like your node consumes abt. 0.1J per transmission-intervall. imho this is a good but not an unusual value.
The energy contained in your battery is abt. 10 kJ. More than 100k transmissions should be possible.
You dont need one !
I do have a UCurrent Gold, but hardly ever use it, its much easier to use a conventional multimeter for sleep current measurements. You can measure low currents for microcontroller projects very easily, all you need is a bit of wire, see here;
