whisky_jb
(Jörg Bieri)
January 30, 2021, 5:28pm
1
Hello, I’m a 100% beginner to LoRaWan, just got my Lorix One Gateway and started to dig into the topic. Here’s what I did:
Installed the gateway, has network connectivity
Registered the gateway in TTN V3
Configured the Gateway accordingly
While everything seems to work, the connection from gateway to TTN doesn’t succeed, I get the following error:
2021-01-30 17:26:26.041 [TCE:VERB] Connecting to MUXS…
key usage : Key Cert Sign, CRL Sigx00
2021-01-30 17:26:25.998 [AIO:INFO] tc has no key+cert configured - running server auth only
2021-01-30 17:26:26.610 [AIO:ERRO] [3] WS upgrade failed with HTTP status code: 401
So it looks like an authorization issue but I have no clue how to fix this. Any ideas
Best regards
Jörg
Hi Jorg! Welcome to the forums. It sounds like you’re getting a great start!
To configure the gateway, are you using Basic Station LNS or CUPS? It looks like you need to make sure you upload the correct CA cert and token. See instructions for both in the CUPS/LNS docs, try LNS first as it’s a little easier → LoRaWAN Network Server (LNS) | The Things Stack for LoRaWAN
The cert you need on that gateway is the DST Root X3 → Root Certificates | The Things Stack for LoRaWAN
whisky_jb
(Jörg Bieri)
February 4, 2021, 11:42am
3
Installed X3, but still get error:
2021-02-04 11:27:58.056 [AIO:INFO] TLS server certificate verification failed: The certificate is not correctly signed by the trusted CA
I’m connecting to V3 stack, is that OK?
whisky_jb
(Jörg Bieri)
February 4, 2021, 1:44pm
4
Finally solved the issue. Uploaded new certificate and also new API key, now the gateway is online.
ngalfas
(Nick Galfas)
February 17, 2021, 7:32pm
5
PolytechTTN
(Polytech Ttn)
November 29, 2022, 10:23am
6
Hello
I have a connection problem to The Things network with the Lorix One.
I followed the explanation here :
https://iot.wifx.net/docs/lorix-os/1.5/wifx-l1/user-s-guide/lorawan/lorawan-networks/the-things-network-industries/the-things-network-v3
But I have still this log :
station
diagnose
key usage : Key Cert Sign, CRL Sign
station
diagnose
certificate policies : An2022-11-29 10:15:39.784 [TCE:INFO] Connecting to INFOS: wss://eu1.cloud.thethings.network:8887
station
diagnose
2022-11-29 10:15:49.879 [AIO:ERRO] [-1] WS connect failed: NET - Failed to get an IP address for the given hostname
station
diagnose
2022-11-29 10:15:49.881 [TCE:ERRO] TC connect failed - URI: wss://eu1.cloud.thethings.network:8887
station
diagnose
2022-11-29 10:15:49.885 [TCE:INFO] INFOS reconnect backoff 0s (retry 0)
station
diagnose
2022-11-29 10:15:50.339 [AIO:INFO] ./tc.trust:
station
diagnose
cert. version : 3
station
diagnose
serial number : 5E:C3:B7:A6:43:7F:A4:E0
station
diagnose
issuer name : CN=ACCVRAIZ1, OU=PKIACCV, O=ACCV, C=ES
station
diagnose
subject name : CN=ACCVRAIZ1, OU=PKIACCV, O=ACCV, C=ES
station
diagnose
issued on : 2011-05-05 09:37:37
station
diagnose
expires on : 2030-12-31 09:37:37
station
diagnose
signed using : RSA with SHA1
station
diagnose
RSA key size : 4096 bits
station
diagnose
basic constraints : CA=true
Do you know where it come from ?
Thanks for yout help
Yann
