I am aware that a real situation means to follow the LoRaWAN rules, but I insist, it is a simulation sending data through UDP to a TTN stack launched on my computer, so do not worry, I am not breaking the rules (and of course, I am not pretending to do so).
Once this issue has been solved, I will keep working on uplink procedure, that it is the next step, thank you very much for all your support! All of your suggestions have been so helpful!
You really, really missed the point of what you were responding to.
It doesnât sound like your simulation is modeling the actual behavior of a network.
As a result, your results will be meaningless at best, but it may be far worse if you actually believe or represent them to others as having any sort of meaning.
I will try to summarize as much as possible the problem I have. I am developing an application to simulate some LoRaWAN devices, and I need to comunicate them to the TTN platform, using the TTN stack with dockers. Even though both the âstatâ and the âjoin-acceptâ procedures seems to be all right (the second one thanks to you guys), when I try the âuplinkâ, a mistake is given from the gateway (I am using the Semtech UDP Packet Forwarder communication). Moreover, the documentation followed in the one regarded to the LoRaWAN v1.0.3.
Letâs see the mistake on the gateway side:
It might be not very relevant, but it is also included a picture of the device side:
In case it may help, I am including the JSON returned by that error: error.json (1013 Bytes)
More clues:
In order to corroborate that the âjoin-acceptâ is working well (or that is what it seems), it can be checked by the print done in my program:
devAddr -> B4634D01
nwkSKey -> 1910482B5841434E6A4FEF4D8999741A
appSKey -> 5E968317B4A01D19C80CDBA349F0732A
By this, has anyone had this kind of mistake? If true, what could it be and how it can be solved? If not, what is the best way to find out what is going on?
Thanks beforehand, looking forward to hearing from you soon.
You have an endian mixup error in your simulated node: notice how when the network is issuing the join accept the bytes of the device address are in the opposite order from what is received in the attempted uplink.
Given that device addresses are not globally unique, you could also potentially get a device not found issue if the MIC of the message does not match due to network session key issues, as itâs getting a matching MIC which validates that the traffic is from the correct instance of the non-unique device address.
But itâs definitely going to be not found when you reverse the byte order of the device address itself as you have in this attempt, so fix that first.
First of all, I am truly sorry for creating a new topic for this new issue, I really thought that they could be treated as separated discussions.
Regarding to the current issue:
Fixed! My bad! Now the only variables that are lsb are appEUI and devEUI⌠but I am afraid the same error is given , take a look to the following pictures:
Regarding to this, is there something I am missing? Do I have to revise all the LoRaWAN packet? That is to say, these elements: MHDR | DevAddr | FCtrl | FCnt | FOpts | FPort | FRM Payload | MIC
I will try this sending to the TTN console V2, just in case I could have more clues.
See if your traffic validates in the online lorawan packet decoder.
Youâve set yourself a huge project here where re-implementing LoRaWAN from scratch is being treated as a trivially implicit part, rather than the large project it actually is.
Youâre going to need to improve your own debugging game quite a bit to get this to work.
Maybe should should spend some time with known good implementations firstâŚ
Beware that even once you start generating valid uplinks, youâre still going to have to deal with MAC configuration downlinks correctly, or youâll get stuck in a loop on those distorting any picture of network performance.
After seeking deeply what was going on, I finally achieved sending data to the device itself registered on the ttn stack, just as it is seen in the picture below:
Data in hexadecimal -> 543A32372E30383B483A32362E3436
Data in ascii -> T:27.08;H:26.46
The change was in the fctrl parameter, setting that the adaptive data rate will be used. It is weird, since another value (e.g. 0x00) give me the classical issue Host cluster failed to handle message.
Sorry if this is something trivial for all of you guys, but⌠Can anyone give me an idea of what this is happening? Am I missing something that might be relevant?
Thanks beforehand, looking forward to hearing from you.
Even in simulation I think sending ASCII text is not the way to go. It sets a wrong example and wonât match real world where binary encoded data will be transmitted. (Or should be transmitted)
You are not showing the message so it is hard to comment. Fctrl can be zero as far as I know but other header fields may have impact on what should be there.
For most forum users this will be something theyâll never encounter as few work on the internals of a LoRaWAN stack. However if you are working on it as you are you should read the LoRaWAN specification front to back and back to front and make sure you understand it. Have you done so?
