May LoRaWAN be used in Haiti? And if so, at what frequency? And is there anything else that needs to be considered?
We want to setup some small Cells there for monitoring sensors.
LoRa Alliance Regional Parameters does not determined a plan for Haiti, perhaps lack of available regulatory documentation
https://lora-alliance.org/resource-hub/rp002-100-lorawanr-regional-parameters
Z-Wave Alliance shows 915 MHz and is listed with Argentina and Honduras
Argentina and Honduras have AU915 listed in LoRa Alliance Regional Parameters
AS923/AU915 - 915-928 MHz
US915 - 902-928 MHz
AS923 seems to be preferred to AU915 in LoRaWAN communities
Hello @eisenkoch
Hope all is well.
Did you find an answer for your question?
It may be simpler to ask your radio regulatory body in Haiti for an official answer …
