LoraButton cannot join to dragino gateway, no logs
I’m using a LoRaButton RAK LB801 to connect to TTN through a Dragino gateway using LoRaWan protocol.
but when i tried to make an OTAA join it failed, it just say “Fail” when i execute the “at+join=otaa”
i already check the logs on the gateway and they are empty, but the configuration seems alright
here is an image with the configuration
bc768d4c68052b45f32d2873ce36c98577edeae7_2_375x500
so please any idea about why the gateway doesn’t receive the button signal even though it’s online is very much appreciated
here is the configuration i used on TTN
botonTTN
here is the config of the button
at+get_config=app_eui
OK70B3D57ED001B95E
at+get_config=dev_eui
OK002141E263E58488
at+get_config=app_key
OK655E9F22EFFCC7753CD9768D0884BD09
You asked the same at the RAK support forum :roll_eyes:
yes but I still don’t get an answer
where can i find it?
who must I ask ?
nobody knows?
make sure that your button AND your gateway work on the same channel.
but first check if your gateway is registered @ TTN and working ok… did you upgrade
to the latest firmware ?
use search in this forum… there is more info
