Hello @ all
I need to manage a Gateway to receive Data over Lora and paste it to my own MQTT Broker for use the Data in Homeassistant. I think that is not only for me useful so maybe some of you are interested too in doing this
At the Moment I have copy and paste 2 codes together but it sends not the right infos to my broker I think it s only a little problem in the code but I see it not
maybe some of you see it faster because you look the code first. time and not like me every day
I want to let the code simple and little as possible because I donโt want to mess up with many libraries and stuff I donโt need for this โsimpleโ read and past code.
Here is the gateway code :
SimpleMQTTClient.ino
The purpose of this exemple is to illustrate a simple handling of MQTT and Wifi connection.
Once it connects successfully to a Wifi network and a MQTT broker, it subscribe to a topic and send a message to it.
It will also send a message delayed 5 seconds later.
#include "EspMQTTClient.h"
#include <SPI.h>
#include <LoRa.h>
#define PIN_NSS 18
#define PIN_RESET 14
#define PIN_DIO0 26
EspMQTTClient client(
"192.168.2.200", // MQTT Broker server ip
"MQTT", // Can be omitted if not needed
"...", // Can be omitted if not needed
"TestClient", // Client name that uniquely identify your device
1883 // The MQTT port, default to 1883. this line can be omitted
void setup()
Serial.begin(115200);
LoRa.setPins(PIN_NSS, PIN_RESET, PIN_DIO0);
while (!LoRa.begin(866E6)) {
Serial.print(".");
delay(500);
LoRa.setSyncWord(0xC6);
Serial.println("[OK]");
// Optionnal functionnalities of EspMQTTClient :
client.enableDebuggingMessages(); // Enable debugging messages sent to serial output
client.enableHTTPWebUpdater(); // Enable the web updater. User and password default to values of MQTTUsername and MQTTPassword. These can be overrited with enableHTTPWebUpdater("user", "password").
client.enableLastWillMessage("TestClient/lastwill", "I am going offline"); // You can activate the retain flag by setting the third parameter to true
// This function is called once everything is connected (Wifi and MQTT)
// WARNING : YOU MUST IMPLEMENT IT IF YOU USE EspMQTTClient
void onConnectionEstablished()
// Subscribe to "mytopic/test" and display received message to Serial
client.subscribe("mytopic/test", [](const String & payload) {
Serial.println(payload);
// Subscribe to "mytopic/wildcardtest/#" and display received message to Serial
client.subscribe("mytopic/wildcardtest/#", [](const String & topic, const String & payload) {
Serial.println("(From wildcard) topic: " + topic + ", payload: " + payload);
// Publish a message to "mytopic/test"
// client.publish("mytopic/test", "This is a message"); // You can activate the retain flag by setting the third parameter to true
void loop() {
int packetSize = LoRa.parsePacket();
if (packetSize) {
Serial.print("Received packet: ");
while (LoRa.available()) {
Serial.print(LoRa.readString());
client.publish("mytopic/heltec", LoRa.readString());
Serial.println(" (RSSI = " + String(LoRa.packetRssi()) + ")");
client.loop();
Notice: Please know ! Its NOT for act over TTN it is simple gateway only here for Lora packet like from the Sandeep Mistry send over a node then receive by this gateway build for heltec V2 board and parse over wifi to a MQTT Broker .
Hope somebody see my failure and maybe other can use this code too for there plans and stuff.
regards from Germany
Marc
