Hello
Has anyone such similar experience? My OTAA node works perfectly fine with TTN - joinRequest/acceptRequest/Uplink/DownLink when first powered on, followed by uplinks every 30 sec (this is only in test mode, it would be transmitting every 5min in actual run). But when I use it with LoRaServer, the activation goes fine, but then the node stops transmitting - the node has ADR=true, but it seems always transmitting with dr = 4/5 with TTN.
But when using with LoRaServer, I see the following after activation: “ADR Request” is sent to the node to set DR >> req_dr=6. And then node stops responding. Does that mean my node able to handle dr=6?
Any help will be very much appreciated
thanks
