INFO | Creating Firmware Over the Air (FOTA) Container
INFO | Binary File: C:\Users\a827879\XDK-Workspace\LoRaThingsNetworkDemo\debug\LoRaThingsNetworkDemo.bin
INFO | Header Version: 0100
INFO | Product Class: 0010
INFO | Product Variant: 0000
INFO | Firmware Version: 00000000
INFO | Set device 'XDK Device 1' into bootloader mode
INFO | Port 'COM4' has been disconnected
INFO | Connecting to XDK device 'XDK Device 1' in port 'COM4'...
INFO | Connection to port 'COM4' established
INFO | Flashing file 'C:/Users/a827879/XDK-Workspace/LoRaThingsNetworkDemo/debug/LoRaThingsNetworkDemo.bin'...
INFO | XDK DEVICE 1: Ready
INFO | XDK DEVICE 1: C
INFO | XDK DEVICE 1: XMODEM Download Success
INFO | XDK DEVICE 1: c
INFO | XDK DEVICE 1: CRC of application area
INFO | XDK DEVICE 1: CRC000015A5
INFO | Application checksum '15a5' successfully verified.
INFO | Transmission successfully completed!
INFO | Booting application...
INFO | XDK DEVICE 1: b
INFO | XDK DEVICE 1: Jumping to application
INFO | XDK DEVICE 1: [XDK][LORA] Hardware DevEUI: [id] configure the same in the application server
INFO | XDK DEVICE 1: AppControllerFire : LoRa Join Failed hence suspended the task...
So I don’t know what to do.
I had troubles configuring my end device because I don’t know much about it.
I chose the recommended Europe frequency plan and the LoRaWAN Spec 1.0.0.
If there is a Join-Accept coming from the gateway, the usual reason for a device not to hear it is that it is too close to the gateway and the signal is too powerful for the device & it is not hearing it properly. We recommend 5m and a brick wall apart.
It’s most likely stopped even doing Join-Accepts because you are cycling back through the DevNonces from the beginning - so you should reset the MAC - there is a button on the console to do that - it will clear the information at the Network Server end so you can start again.
Ok thanks, now I don’t have messages anymore when I flash the demo (just “LoRa Join Failed hence suspended the task” in the xdk workbench console). I cleared everything and even deleted and created again the application but still doesn’t work.
How can I put my device 5m away from my computer since it’s connected to it? Am I missing something ?
Difficult to tell from the info you linked to and the bosch links do not appear to work or throw up security advisories…I note that the info is very old (2018, despite the pdf 2019 ref) dating back to old TTN V2. From the picture I assume the XDK is the sensor module under eval and the LoRa extenstion is an add on - based on MIcrochip RN2483?) that then grafts a LoRa radio onto the XDK, with correct software no doubt this can then enable the fulll set up to act as a LoRaWAN node, with the RN Module providing the LoRaWAN stack… but I see nothing about a Gateway at this point… if you found it briefly connected once then maybe you were just in range of a public community gateway, but conditions changesa and cant now be reached… have you looked that the local community or TTN map to see where you are relative to any community GW’s if you dont have your own? If in range then Nick’s advice wrt connection setting may well apply…
…also wrt LoRaWAN 1.0.0 this can possibly be made to work (I have some early kit that limps along!) but recommendadtion is that for TTN V3 you really need to be looking at 1.02 or later, due to NS expectations and MAC handling… look for updated firmware
Note also the document you linked to only talked about setting up your TTN application and the device - no info on GW set up, so unless youhave alternate you may struggle…
For speed and cost I would suggest just grab a TTIG or a LPS8 or equivalent… there are several GW’s available in the $70-150 range if you look around… Just make sure you get a LoRaWAN GW, not a reduced function LoRa only GW/PF with <8 channels…
