Lora duplex send but cant receive answer
hi guys. I have confused these days by Lora Library. what I want to do is send and receive data with SX1278 Module(https://cutt.ly/zbDX8K4) and Arduino Uno… I send message to node2 and node2 send his answer ( with Answer(); ) to node1. but after 3 or 4 times it corrupt.
sender:
#include <SPI.h>
#include <LoRa.h>
unsigned char Hiall[] = "Gateway";
String Byte;              // outgoing message
long lastSendTime = 0;        // last send time
void setup(){
  Serial.begin(9600);
  while (!Serial);
  Serial.println("LoRa gateway");
  if (!LoRa.begin(433E6)) {
    Serial.println("Starting LoRa failed!");
    while (1);
 LoRa.onReceive(onReceive);
  LoRa.receive();
void loop() {
if(runEvery(3000)){
     HiAll(Hiall);
  LoRa.receive();
void onReceive(int packetSize){
  if (packetSize == 0) return;
  String incoming = "";
  while (LoRa.available()){
    incoming += (char)LoRa.read();
  Serial.println(incoming);
void HiAll(String Byte){
LoRa.beginPacket();                   // start packet
  LoRa.print(Byte);                 // add payload
  LoRa.endPacket();                     // finish packet and send it
  Serial.println("Sending " + Byte);
boolean runEvery(unsigned long interval)
  static unsigned long previousMillis = 0;
  unsigned long currentMillis = millis();
  if (currentMillis - previousMillis >= interval)
    previousMillis = currentMillis;
    return true;
  return false;
receiver:
#include <SPI.h>
#include <LoRa.h>
unsigned long Time = 10000;
String outgoing;              // outgoing message
int interval = 3000;          // interval between sends
void setup() {
  Serial.begin(9600);
  while (!Serial);
  Serial.println("LoRa node");
  if (!LoRa.begin(433E6)){
    while (1);
    LoRa.receive();
void loop() {
  if(runEvery(3000+random(100))){
     LoRa.receive();
void onReceive(int packetSize) {
  while (LoRa.available()) {
  Serial.print("Received: " + incoming);
 Check();
void Send(String Byte){
  Serial.println("Sending "+Byte);
void Check(){
                  String ANSWER = "Receive:  Im Node";
                Send(ANSWER);
boolean runEvery(unsigned long interval){
    return true;
  return false;
result is:
Sending Gateway
receive: Im node
Sending Gateway
receive: Im node
Sending Gateway
receive: Im node
Sending Gateway
receive: Im node
Sending Gateway
receive: Im node
GGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGG GGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGG
I have good power , good connection. i think the problem is working with LoRa.onreceive(); please help me. do you know better library?? or its about my code??
How is this connected to LoRaWAN & TTN? Note LoRaWAN not LoRa p2p/proprietary…
it isn’t connected to server. this is just communication between 2 nodes.
Then its a subject not supported on this TTN forum.
TTN does not use node to node communication.
Your question is really not even about LoRa, but on how to use two Arduinos with a particular Arduino library.
