Lora-dl: [TTN V3 (eu1)] Keepalive timed out
Hi, I have lot of this msg in log, what is wrong ?
We have public IP without any limits (port, traffic etc…)
Is possible run two and more gateways on the same public IP , the same internet connection… ?
Thank
Yes it is!
Anyone info about Keepalive timed out error in log ?
https://www.thethingsnetwork.org/forum/search?q=Keepalive
What gateway brand? What packet forwarder? A bit more information as well as searching the forum goes a long way.
Gateway is Mikrotik wap LR8 kit, main router is RB4011 direct to optical network
But many articles are not resolved…
Which means that some are and/or they may prompt you to look at some elements of your setup independently of the answers given here.
Hi, unfortunately, I didnt find anything in the last articles that would lead me to rebuild something…
I dontt know what to re-setup :confused:
What is the originating UDP port used by the LR8? (The target port is 1700)
Yes, original is 1700 up/down
If the origin port is not a random one you won’t be able to use multiple gateways behind one NAT router as there won’t be a way to create multiple NAT sessions. NAT requires the combination of source port (within the local LAN), destination IP and destination port to be unique.
I can use random port ? For example 8888 and for next GW 9999 ? Setup make just in GW or also in TTN console ?
Thank
The destination port is always 1700. If you are able to specify a source port you can use any value you like without the need to configure it at TTN side.
Im sorry, but I dont know exactly what you mean.
Change port in GW to xxx and in main router change back to 1700 ? Or ?
Please read up on NAT and UDP so you know what happens/is supposed to happen at the internet gateway router.
Im sorry, but I would need info about the exact settings
