We are proud to announce that Thomas Telkamp (@telkamp), our network architect with over 20 years of experience in large-scale networking, is giving a webinar on November 10. Thomas will provide you with the essential technical information so you can make best use of the product you are about to receive.
I’d far rather see a high gain antenna then reduce the transmit power so the radiated power is within the limits. That way you get the benefit of better receive signal levels. Is it possible to modify the gateway transmit power with TTN?
The latest version of packet forwarder (3.0.0+) has an option to specify “antenna_gain” in the global_conf.json. If you fill in the gain of your antenna here (minus 2.15 dBi for EU, minus 6 dBi for US), the tx power will be limited accordingly.
Be aware though that you might create situations where downlink does not work, and for example devices can’t join the network.
why would this asymetric situation really hurt? If I understand the antenna theory right using an antenna with a higher gain does not have real drawbacks. That is when you stay within reasonable limits. So why not just consider the additional range as a kind of gift useful for devices that only transmit?
Yes, that’s certainly true. But the backend should know about the extra gain, such that it can take that into account when making a downlink decision if there are more gateways. This is currently not possible, but we should put it on the feature list. I’ll create an issue for this.
I tried to download the slides of Thomas his webinar form the LoRa Crash course. But the slides don’t match the youtube video. Is it possible to add the correct slides?
@fab_2solve I’m afraid the slides are no longer available. The slides in my earlier post correspond for the largest part with the video. Hopefully this works for you as well.
