Hey guys,
I’m trying to connect lansitec products, like GW BLE nodes (LoRa Indoor Bluetooth Gateway : Lansitec® | LoRa), I’m using a ttn gateway (https://www.thethingsnetwork.org/ docs/gateways/gateway/) with the following configuration:
I configured the nodes in the ttn application with the information that the manufacturer gave me, the configuration information is below:
however when trying to connect with the device it is in a loop that seems to be not doing the join, below is the node log in the ttn application:
Has anyone had this problem or can tell me if it’s a configuration problem?
p.s: I’m using GW in Brazil.
