We are going to implement two new gateways. They will (sometimes) be used at different locations (workshops).
What is the right/best information in the settings? Lat/lon = 0.0?
No, those gateways should not provide location information at all. What hardware/software will you be using?
We will use LORIX One gateways. Is it ok to set the location temporary just to show how it works?
You have two options:
Any other option might produce invalid results for someone depending on location information being correct, including using 0,0. (What would your software do if a gateway at 0,0 reported it has received your packet?)
Ok, option 1 is the way we’ll do it. Thanks!
