I’m trying to use the IBM LMIC lib to transmit from my node to a Gateway over LoRa.
Everything is working nice so fare, but there’s something I don’t like about the LMIC lib:
Isn’t it possible to use the lib without its OS functionality? Normally it is necessary to always call “os_runloop()” in the main loop.
I plan to sleep until an interrupt occurs and then to do a transmission - that’s it.
Does someone has an idea how to do that without too much changes in the lib?
