Continuing the discussion from Transmit Failure after days using LMIC library and Arduino IDE
Hi i’m having the same issue ecosoph had with lmic failure.
I’ve seen ecosoph found a solution by “forcing the MCU to sleep after a transmit failure”.
Can anyone show me the code to do this fix ?
Best regards
José Salvador
