I did some more testing but do get nowhere.
I tried both the library from matthijskooijman and the supposedly newer (improved?) one here: mcci-catena/ arduino-lmic
but both behave the same.
The IDE used is Arduino 1.8.5.
Regarding the code, I am not sure if I can/should post a quite long code here. It is mainly the example otaa code with some modifications to put the Arduino to sleep.
What is very strange is, that the effect starts usually only after some hours.
Here is one example with a code that wakes up once per minute and tries to send once per hour:
Joining looks like that:
Starting
sending...
4027: Packet queued
4080: EV_JOINING
11167: EV_TXSTART
332332: EV_JOINED
333199: EV_TXSTART
403949: EV_TXCOMPLETE (includes waiting for RX windows)
alt: 10:19:55
neu: 10:19:57
Received 3 bytes of payload
sent
... go to sleep
woken ... IRQ
-RTC- 20:0 ... go to sleep
woken ... IRQ
-RTC- 21:0 ... go to sleep
Then after one hour, a packet is sent:
-RTC- 58:0 ... go to sleep
woken ... IRQ
-RTC- 59:0 ... go to sleep
woken ... IRQ
-RTC- 0:0 sending...
151569065: EV_TXSTART
151569279: Packet queued
151639348: EV_TXCOMPLETE (includes waiting for RX windows)
alt: 11:0:1
neu: 11:0:11
sent
... go to sleep
woken ... IRQ
-RTC- 1:0 ... go to sleep
woken ... IRQ
-RTC- 2:0 ... go to sleep
This goes on for three hours and then this happens:
woken ... IRQ
278556535: Packet queued
329882220: EV_TXSTART
329952504: EV_TXCOMPLETE (includes waiting for RX windows)
alt: 14:13:41
neu: 14:14:1
sent
... go to sleep
The Packet queued message now comes way before the TX_START, because other than in the hours before, the LMIC seems to delay the sending for 13 minutes in this case.
It can be seen from the RTC printout that usually send is within the minute but here it is after 13 minutes.
Why is it doing this? And how can I avoid it.
The code where I schedule the sending is:
os_setTimedCallback(&sendjob, os_getTime() + ms2osticks(10), do_send);
and in the do_send I do this
Serial.println(F(" sending..."));
LMIC_setTxData2(1, message.getBytes(), message.getLength(), 0);
Serial.print(os_getTime());
Serial.print(": ");
message consists of 16 bytes put together by LoraMessage.h
After the send it runs the os_runloop_once(); in the loop() until TX_Complete and goes to sleep again.
