I have the issue of uplinks downlinks with no payload since integrating TTN with AWS. It seems that the node is not ack whatever AWS IoT or TTN is sending on the port 0 uplinks.
If it was only ADR there would be only one uplink downlink and the node would respond changing the rate, but in this case the uplinks continue.
The interesting thing is that uplink downlink from TTN console also stops working. When I delete the Stack of the integration on AWS Elastic BS, this issue goes away and also the port 0 uplinks cease.
Can somebody advise how to debug what AWS IoT of the Stack is sending to get this behaviour?
Yes, cslorabox, sorry about that, Downlinks keep being generated with empty payload on port 0. I have run the decoder but there are no ADR acks requests. As soon as I delete the EB Stack , they are gone.
