Limit to number of HTTP Integrations? Any Logs available?
Can anyone confirm if there’s a limit to the number of HTTP integrations you can have for a single TTN Application?
We’ve got data coming up from devices and showing ok in the Data tab within the Console.
But it looks like no HTTP or HTTPS POST requests are being generated.
I’ve tried registering https://postb.in, https://beeceptor.com/ and my Lambda application thru AWS API Gateway as integration endpoints. But we’ve received no POSTs at all over the last few days from TTN.
Is there any sort of logging generated by TTN that we can inspect, to make sure our endpoints are being reached ok?
Any insights appreciated!
I was wondering the same. But I can confirm that I’m now running 2 HTTP integrations concurrently.
I also had the same question regarding logging on TTN side, but I don’t think there is any. I ended up doing tcpdump and figuring out that TTN was rejecting my certificate.
see How to troubleshoot HTTP integration for more details.
