Hello everyone!
I was wondering if there is a way to “force” LGT-92 to send a message? I know that there is ALARM button, but i would like to do something similar remotely, to check if device is working correctly by sending some command via Telegram. I checked the downlink commands list, but i couldn’t find the correct one.
You probably need to read up on downlinks and class A devices. To be able to send anything to a class A device it needs to send an uplink. So you need the device to send data to be able to receive the ‘force transmission’ command.
Would that be a useful solution? I doubt it…
Yeah, You are probably right… Thank You for the fast response
imho the LGT-92 supports class a only. If you want to request the upload of a position by a download you need a class c device.
