LGT-92 and TTN Mapper
I am a newbie in Lorawan and I just received my LGT-92 tracker with a LPS8 Gateway.
I try to link my tracker to TTN Mapper and I think it doesn’t work.
I used the payload from Dragino website:
> /*function Decoder(bytes, port) {
> // Decode an uplink message from a buffer
> // (array) of bytes to an object of fields.
> var value=bytes[0]<<16 | bytes[1]<<8 | bytes[2];
> if(bytes[0] & 0x80)
> value |=0xFFFFFF000000;
> var latitude=value/10000;//gps latitude,units: °
> value=bytes[3]<<16 | bytes[4]<<8 | bytes[5];
> if(bytes[3] & 0x80)
> var longitude=value/10000;//gps longitude,units: °
> var alarm=(bytes[6] & 0x40)?"TRUE":"FALSE";//Alarm status
> value=((bytes[6] & 0x3f) <<8) | bytes[7];
> var batV=value/1000;//Battery,units:V
> value=bytes[8]<<8 | bytes[9];
> if(bytes[8] & 0x80)
> value |=0xFFFF0000;
> var roll=value/100;//roll,units: °
> value=bytes[10]<<8 | bytes[11];
> if(bytes[10] & 0x80)
> value |=0xFFFF0000;
> var pitch=value/100; //pitch,units: °
> return {
> Latitude: latitude,
> Longitud: longitude,
> Roll: roll,
> Pitch:pitch,
> BatV:batV,
> ALARM_status:alarm,
> //The function is :
> var latitude=0;//gps latitude,units: °
> if(bytes[0] !== 0)
>   latitude=(bytes[0]<<24 | bytes[1]<<16 | bytes[2]<<8 | bytes[3])/1000000;//gps latitude,units: °
> else
> var longitude = 0;
> if(bytes[4] !== 0)
>   longitude=(bytes[4]<<24 | bytes[5]<<16 | bytes[6]<<8 | bytes[7])/1000000;//gps longitude,units: °
> else
>  longitude=0;//gps longitude,units: °
> var alarm=(bytes[8] & 0x40)?"TRUE":"FALSE";//Alarm status
> var batV=(((bytes[8] & 0x3f) <<8) | bytes[9])/1000;//Battery,units:V
> if(bytes[10] & 0xC0==0x40)
>   var motion_mode="Move";
> else if(bytes[10] & 0xC0 ==0x80)
>   motion_mode="Collide";
> else if(bytes[10] & 0xC0 ==0xC0)
>   motion_mode="User";
> else
>   motion_mode="Disable";
> }                                            //mode of motion
> var led_updown=(bytes[10] & 0x20)?"ON":"OFF";//LED status for position,uplink and downlink
> var Firmware = 160+(bytes[10] & 0x1f);  // Firmware version; 5 bits
> var roll=(bytes[11]<<8 | bytes[12])/100;//roll,units: °
> var pitch=(bytes[13]<<8 | bytes[14])/100; //pitch,units: °
> var hdop = 0;
> if(bytes[15] > 0)
>    hdop =bytes[15]/100; //hdop,units: °
> else
>    hdop =bytes[15];
> var altitude =(bytes[16]<<8 | bytes[17]) / 100; //Altitude,units: °
> return {
> Latitude: latitude,
> Roll: roll,
> Pitch:pitch,
> BatV:batV,
> ALARM_status:alarm,
> MD:motion_mode,
> LON:led_updown,
> FW:Firmware,
> HDOP:hdop,
> Altitude:altitude,
I have all that’s required by TTN Mapper: Latitude, Longitude, Altitude and Hdop.
TTN Mapper is integrated to my Application. But in TTN Mapper, when I go in “Advanced Maps” and I enter the Device ID of my LGT92 I don’t see any point. But I can see data in my Console.
Is there something wrong? Location on TTN Mapper is real time?
Well it works know.
I removed TTN Mapper from my Integration and I added it again. And know it works!
Perhaps the modifications i have made in the decoder are usefull for you too.
Have a look at this post:
