LG308 latest Firmware for IOT V3 does not connect (IOT V2 & V3)
Hi all,
i updated my LG308 to dragino-lgw–v5.4.1618196981 and did not manage to reconnect to my V2 Thingsnetwork or even to the new V3 IOT.
If i try to “save & apply” the log shows:
Mon Apr 19 14:16:02 2021 user.notice root: ttn
Mon Apr 19 14:16:02 2021 daemon.err uhttpd[1692]: Command failed: Not found
Mon Apr 19 14:16:05 2021 daemon.err uhttpd[1692]: sh: write error: Resource busy
Mon Apr 19 14:16:05 2021 user.notice iot_keep_alive: Internet Access OK: via eth1
Mon Apr 19 14:16:05 2021 user.notice iot_keep_alive: use WAN or WiFi for internet access now
Mon Apr 19 14:16:06 2021 daemon.err uhttpd[1692]: sh: LG308: unknown operand
Mon Apr 19 14:16:06 2021 daemon.err uhttpd[1692]: sh: LPS8: unknown operand
Mon Apr 19 14:16:06 2021 daemon.err uhttpd[1692]: sh: DLOS8: unknown operand
Mon Apr 19 14:16:06 2021 daemon.err uhttpd[1692]: sh: LIG16: unknown operand
The firmware LG02_LG08-5.4.1594972541 connects without problems to V2 with no new configuration directly after FW-Upgrade , but it does unfortunately not have V3.
FW Downloaded from: Dragino Download Server ./downloads/LoRa_Gateway/LG308-LG301/Firmware/
I think all FW without LG02_LG08 in the filename don’t work.
Any hints?
Regards
Thomas
i have the LoRaWAN Gateway LG308-EC25 and i update last week with the latest firmware
www.dragino.com/downloads/index.php?dir=LoRa_Gateway/LG308-LG301/Firmware/Release/lgw–build-v5.4.1615882321-20210316-1613/
and i was able to configure and reconnect my Gateway to V3 but i use LORAWAN.
or maybe you need to write the Dragino Support they can help you as well
support@dragino.com
