Where can i found a payload formater (uplink) using in ttn 3 which shows
Battery in 3.xx Volt
Distance in mm or cm ?
Many Thanks
Herbert
Don’t know about the -8 specifically, but usual place is website and device documentation!!! (Have you looked?) Often there isnt much change between versions, unless new features added (I haven’t looked!)
For original LDDS75’s that I have the decoder is below - give it a try - YMMV
var value=(bytes[0]<<8 | bytes[1]) & 0x3FFF;
var batV=value/1000;//Battery,units:V
value=bytes[2]<<8 | bytes[3];
var distance=(value)+" mm";//distance,units:mm
if(value===0)
distance = "No Sensor";
else if(value<280)
distance = "Invalid Reading";
return {
Bat:batV +" V",
Distance:distance
