Launched your “OWN” satellite into Low Earth Orbit.
When we see last fryday the bring 60 small satellites in the low-Earth orbit for Musk’s new Starlink internet service. I think what can we do to this with less money and be all so active in space
After a search on the Internet I saw/found this:
AmbaSat-1: An IoT Space satellite kit
Once your satellite kit is assembled (you can add more sensors to it) and programmed (with your own code), it will be launched onboard on a commercial rocket which will deploy your satellite into Low Earth Orbit, where it will spend up to 3 months in space.
Once your AmbaSat satellite is released from the CubeSat container, it will power-up and begin sending data back to your Dashboard via The Things Network of Gateways. Your AmbaSat-1 is fully Things Network (TTN) compliant so as well as viewing data in your Dashboard, you can sign-up for a TTN account and access your satellite’s sensor data directly using a range of different TTN extensions.
When “your satellite” is finally in space! You have control! true the AmbaSat Dashboard.
And you are you own Satellite Operator.
I have backed, and I hope the project will started, and I will publish here the result’s off building, testing, launced, and the first data.
See the “The AmbaSat-1” printed circuit board (PCB)
All the board components – MCU, transceiver, voltage regulator, resistors, etc : https://tinyurl.com/y5fquqy2
See how the lauche will in the below animation.
See at Kickstarter : https://lnkd.in/dDW-9Tt
