ST B-L072Z-LRWAN1 board with Arduino framework and LMIC.
Does anyone have this combination working?
I’m trying to get this to work but run into some issues:
Description
I use Platformio and have defined disco_l072cz_lrwan1 as board with Arduino as framework.
If I’m correct this will use the STM32 Arduino Core.
LoaRaWAN library used: MCCI LoRaWAN LMIC library.
The sketch is tested proven code that runs without issues on other boards.
My platformio.ini looks like this:
[env:disco_l072cz_lrwan1]
platform = ststm32
board = disco_l072cz_lrwan1
framework = arduino
upload_protocol = stlink
monitor_speed = 115200
lib_deps =
The SX1276 on the Murata module is not connected to the standard SPI port.
Standard SPI is configured using the values MOSI, MISO and SS which are defined as:
MOSI PB15 (11)
MISO PB14 (12)
SCK PB13 (13)
While the SX1276 uses the following:
RADIO_MOSI_PORT PA7 (34)
RADIO_MISO_PORT PA6 (35)
RADIO_SCLK_PORT PB3 (36)
RADIO_NSS_PORT PA15 (37)
RADIO_RESET_PORT PC0 (33)
RADIO_DIO_0_PORT PB4 (38)
RADIO_DIO_1_PORT PB1 (39)
RADIO_DIO_2_PORT PB0 (40)
LMIC can only use the default SPI. I therefore redefine the SPI pins in setup() before calling any LMIC code. Like this:
setup
SPI.setMOSI(RADIO_MOSI_PORT);
SPI.setMISO(RADIO_MISO_PORT);
SPI.setSCLK(RADIO_SCLK_PORT);
SPI.setSSEL(RADIO_NSS_PORT);
SPI.begin();
os_init();
LMIC_reset();
The pin map is:
.nss = RADIO_NSS_PORT,
.rxtx = LMIC_UNUSED_PIN,
.rst = RADIO_RESET_PORT,
.dio = { RADIO_DIO_0_PORT, RADIO_DIO_1_PORT, RADIO_DIO_2_PORT }
Issue 1
The code compiles successfully but uploading fails with the following error message:
Configuring upload protocol...
AVAILABLE: blackmagic, jlink, mbed, stlink
CURRENT: upload_protocol = stlink
Uploading .pio\build\discovery-l072z-lrwan1\firmware.elf
xPack OpenOCD, 32-bit Open On-Chip Debugger 0.10.0+dev (2019-07-17-07:34)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
debug_level: 1
srst_only separate srst_nogate srst_open_drain connect_deassert_srst
Error: init mode failed (unable to connect to the target)
in procedure 'program'
** OpenOCD init failed **
shutdown command invoked
*** [upload] Error 1
The ST-Link drivers v2.0.1 are installed (running on Windows 10).
In Device Manager the board is visible as STMicroelectronics STLink Virtual COM Port (COM17)
In Device Manger the board is recognized as ST-Link Debug.
In the system tray the board is visible as STM32 STLink (with drive DIS_L072Z).
It looks like everything is installed and configured correctly but the upload fails.
Issue 2
As workaround for issue 1 I have upgraded the on-board ST-Link programmer to J-Link OB.
After the upgrade the board is recognized as COM port ‘JLINK CDC UART Port’
For JLink the upload_protocol in platformio.ini must be set to jlink.
After these changes I was able to upload the sketch to the board and even got output in the serial monitor via the (JLink) USB port.
When trying to run the sketch, it hangs after a packet is queued. In the middle of printing text to the serial port (probably while handling the EV_TXSTART event):
000000000267: Event: EV_JOINING
000000000410: Packet queued
00
The join request is never transmitted (not visible in TTN Console).
Questions
What could be causing these issues?
Any ideas how to fix them?
Update:
A workaround for Issue 1 is to use upload_protocol = mbed instead of stlink (which is default).
But that also requires upload_port to be specified, in my case upload_port = F:
The mbed upload protocol uses Mass Storage for firmware upload (which is actually a file copy) and therefore the board’s drive letter has to be set as upload_port (the value of upload_port is platform specific).
