I’m very interested in join this course. I’ve one question, if you don’t mind, to do the hands-on workshops, I assume we need to access to a hardware kit as is said in the web. Do you know what is the required purchase list of hardware that we need to take properly the course?
It says it’s coming soon but if you need to budget, at worst case scenario you are likely to need a gateway and an end device as bare minimum plus, I hope obviously, a computer on the internet! A TTIG + Arduino MKR WAN 1310 (I’m guessing on some mainstream hardware here) would run to around 150 in £/$/€ tops. Hopefully Laurens is a good negotiator.
Do you have indication from RAK & Arduino by destination territory of when last order date would be to guarantee users will have units in time for the workshops (inc shipping/customs clearance times…)
I can foresee tears by bedtime for those around the world leaving until last minute!
@Faunaphotonics the workshop is designed for the RAK gateway. You can follow along with part of the workshop, but the firmware to manage the RAK gateway card might be different than the one you use.
Hi, I’ve been sitting on one of the original Kickstarter Gateways (with 2 Things Uno boards). All this stuff is still unboxed, life just gets in the way, y’know?
Anyhow this seems like a good time to dive in with some hand holding.
My question is simple, is one of the original TTN kickstarter gateways a suitable device with which to follow along? I also have doubts about V2 to V3 upgrading too, I have always followed along with what is happening TTN-wise, but never had time to participate.
Cheers. Paul.
Received my Arduino kit for the session a couple of days ago and noticed that unlike most other such retail packed modules I’ve received from other vendors (e.g. RAK811Sensor/Tracker, 813, 815, 5205 etc. Heltec WiFi Lora V1 & V2’s etc.) There is NO small antenna/pigtail included - not even a small helical or patch ant…nor is there any warning out of the box to the effect that you should not power up/run LoRa kit without 1st attaching an antenna!
If you didnt order one for the session raid your spares box, cannibalise another unit/system… or get a rapid order into you favourite choice of disty to get a suitable ant delivered in time before you trash your kit!
