So I am using the LoRa Dragino GPS Shield and I have based my code on this Github Repository. The tutorial I followed was from wiki dragino. I have changed the code but for some reason I am unable to get the decoded values correctly. Have I allocated lesser bits for temperature and turbidity sensor? I am using DS18B20 and Turbidity sensor. Here is my code:
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <SoftwareSerial.h>  //Not needed if using Arduino Mega
#include <TinyGPS.h>
TinyGPS gps;
SoftwareSerial ss(3, 4); // Arduino RX, TX to conenct to GPS module.
#define ONE_WIRE_BUS A3
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
float temperature,turbidity,turbidity1;
#define Turbidity_dpin A0
#define Temperature_dpin A3
static void smartdelay(unsigned long ms);
unsigned int count = 1;        //For times count
float flat, flon,falt;
static uint8_t mydata[19] = {0x05,0x67,0x00,0x02,0x68,0x00,0x03,0x88,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x65};
/* LoRaWAN NwkSKey, network session key
   This is the default Semtech key, which is used by the prototype TTN
   network initially.
   ttn*/
static const PROGMEM u1_t NWKSKEY[16] = {  };
/* LoRaWAN AppSKey, application session key
   network initially.
   ttn*/
static const u1_t PROGMEM APPSKEY[16] = {  };
 LoRaWAN end-device address (DevAddr)
 See http://thethingsnetwork.org/wiki/AddressSpace
 ttn*/
static const u4_t DEVADDR = 0x000000;
/* These callbacks are only used in over-the-air activation, so they are
  left empty here (we cannot leave them out completely unless
   DISABLE_JOIN is set in config.h, otherwise the linker will complain).*/
static osjob_t initjob,sendjob,blinkjob;
/* Schedule TX every this many seconds (might become longer due to duty
 cycle limitations).*/
const unsigned TX_INTERVAL = 10;
// Pin mapping
    .nss = 10,
    .rxtx = LMIC_UNUSED_PIN,
    .rst = 9,
    .dio = {2, 6, 7},
void do_send(osjob_t* j){
        Serial.println("OP_TXRXPEND, not sending");
    } else {
        GPSRead();
        Tem();
        printdata();
        //  LMIC_setTxData2(1,datasend,sizeof(datasend)-1,0);
        LMIC_setTxData2(1, mydata, sizeof(mydata), 0);
        Serial.println("Packet queued");
        Serial.print("LMIC.freq:");
        Serial.println(LMIC.freq);
        Serial.println("Receive data:");
void onEvent (ev_t ev) {
    Serial.print(os_getTime());
    Serial.print(": ");
    Serial.println(ev);
    switch(ev) {
        case EV_SCAN_TIMEOUT:
            break;
        case EV_BEACON_FOUND:
            break;
        case EV_BEACON_MISSED:
            break;
        case EV_BEACON_TRACKED:
            break;
        case EV_JOINING:
            break;
        case EV_JOINED:
            break;
        case EV_RFU1:
            Serial.println(F("EV_RFU1"));
            break;
        case EV_JOIN_FAILED:
            break;
        case EV_REJOIN_FAILED:
            break;
        case EV_TXCOMPLETE:
            Serial.println(F(""));
            if(LMIC.dataLen) {
                // data received in rx slot after tx
                Serial.print(F("Data Received: "));
                Serial.write(LMIC.frame+LMIC.dataBeg, LMIC.dataLen);
                Serial.println();
            // Schedule next transmission
            break;
        case EV_LOST_TSYNC:
            break;
        case EV_RESET:
            break;
        case EV_RXCOMPLETE:
            // data received in ping slot
            break;
        case EV_LINK_DEAD:
            break;
        case EV_LINK_ALIVE:
            break;
         default:
            break;
void setup() {
     // initialize digital pin  as an output.
    sensors.begin();
    Serial.begin(9600);
    // ss.begin(9600);
    while(!Serial);
    Serial.println(F("LoRa GPS Example---- "));
    Serial.println(F("Connect to TTN"));
    #ifdef VCC_ENABLE
    // For Pinoccio Scout boards
    pinMode(VCC_ENABLE, OUTPUT);
    delay(1000);
    #endif
    // LMIC init
    os_init();
    LMIC_reset();
    /*LMIC_setClockError(MAX_CLOCK_ERROR * 1/100);
     Set static session parameters. Instead of dynamically establishing a session
     by joining the network, precomputed session parameters are be provided.*/
    #ifdef PROGMEM
    /* On AVR, these values are stored in flash and only copied to RAM
       once. Copy them to a temporary buffer here, LMIC_setSession will
       copy them into a buffer of its own again.*/
    LMIC_setSession (0x1, DEVADDR, nwkskey, appskey);
    #else
    LMIC_setSession (0x1, DEVADDR, NWKSKEY, APPSKEY);
    #endif
    LMIC_setLinkCheckMode(0);
    LMIC.dn2Dr = DR_SF9;
    // Set data rate and transmit power (note: txpow seems to be ignored by the library)
    LMIC_setDrTxpow(DR_SF7,14);
    // Start job
    do_send(&sendjob);
void GPSRead()
  unsigned long age;
  gps.f_get_position(&flat, &flon, &age);
  falt=gps.f_altitude();  //get altitude
  flon == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flon, 6;//save six decimal places
  flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flat, 6;
  falt == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : falt, 2;//save two decimal places
  int32_t lat = flat * 10000;
  int32_t lon = flon * 10000;
  int32_t alt = falt * 100;
  mydata[9] = lat >> 16;
  mydata[10] = lat >> 8;
  mydata[11] = lat;
  mydata[12] = lon >> 16;
  mydata[13] = lon >> 8;
  mydata[14] = lon;
  mydata[15] = alt >> 16;
  mydata[16] = alt >> 8;
  mydata[17] = alt;
void Tem()
       sensors.requestTemperatures();
       temperature = sensors.getTempCByIndex(0);    //Temperature detection
       turbidity1 = analogRead(Turbidity_dpin); //Get A0 Status
       float voltage = turbidity1 * (5.0 / 1024.0);
       turbidity = ((-1120.4*voltage*voltage)+(5742.3*voltage)-(4352.9));
       mydata[2] = temperature;
      // mydata[3]= ; //removed from mydata above
       mydata[6] = turbidity;
void printdata(){
       Serial.print(F("###########    "));
       Serial.print(F("NO."));
       Serial.print(count);
       Serial.println(F("    ###########"));
       Serial.println(F("The temperautre and turbidity :"));
       Serial.print(F("["));
       Serial.print(temperature);
       Serial.print(F("℃"));
       Serial.print(F(","));
       Serial.print(turbidity);
       Serial.print(F("%"));
       Serial.print(F("]"));
       if(flon!=1000.000000)
       Serial.println(F("The longtitude and latitude and altitude are:"));
       Serial.print(flon);
       Serial.print(flat);
      Serial.print(falt);
       count++;
smartdelay(1000);
  unsigned long start = millis();
  do
    while (ss.available())
      gps.encode(ss.read());
  } while (millis() - start < ms);
void loop() {
    os_runloop_once();
