Installing TTN Multi Protocol Packet Forwarder
Installing mp-packet-forwarder (3.0.25) on root.
sh: /tmp/opkg-bRDNHv/mp-packet-forwarder-iPnvG0/preinst: Permission denied
To remove package debris, try `opkg remove mp-packet-forwarder`.
To re-attempt the install, try `opkg install mp-packet-forwarder`.
Collected errors:
* pkg_run_script: package "mp-packet-forwarder" preinst script returned status 126.
* preinst_configure: Aborting installation of mp-packet-forwarder.
* opkg_solver_install: Cannot install package mp-packet-forwarder.
Get up-to-date TTN configuration for packet forwarder
module.js:340
throw err;
Error: Cannot find module '/opt/lora/merge.js'
at Function.Module._resolveFilename (module.js:338:15)
at Function.Module._load (module.js:280:25)
at Function.Module.runMain (module.js:497:10)
at startup (node.js:119:16)
at node.js:945:3
installer.sh: line 826: /etc/init.d/ttn-pkt-forwarder: No such file or directory
The installation is now complete.
Check the gateway output using:
tail -f /var/log/lora-pkt-fwd.log
(It might take some minutes for the first output to appear!)
Check the gateways last seen status in the TTN console after
a few minutes to verify the setup is working correctly
I’m assuming that this is due to the missing javascript library, however I’m struggling to find out how to get those libraries installed.
Switching to mLinux is not an option unfortunately due to client requirements.
Is there a way I can either install the library or fix the permissions to get this working?
I had hoped that the web UI “TTN” dropdown would be sufficient, however that doesn’t appear to be the case as the server is still showing as “not connected” even after saving the settings and rebooting.
For those playing along at home, the only way to use the dropdown for TTN in the GUI is if you select the “legacy” packet forwarder option when adding the gateway to TTN.
As soon as you do that, the gateway shows up as connected in the TTN console and the packets start flowing freely.
Thanks @kersing - to be honest we’re only using these devices because it was the customer request. I’d far rather be using the RAK7249’s given they talk all kinds of different ways to different setups including our own Chirpstack solution and TTN.
I definitely won’t miss configuring the Multitechs…
Hi, I’ve had the same issue with Multitech conduit 5.2.1 firmware, and found that the problem was that the /tmp folder was mounted with noexec option, so opkg cannot execute preinst script.
To make it works I’ve just remounted the /var/volatile mount point (where /tmp points) with the following command: /bin/mount -o rw,exec,remount /var/volatile
Hope that it could help someone!
Thanks - we’ve gone back to the RAK gateways for now, the Multitechs really don’t feel as good as they should for the price they’re being sold at in our opinion, but it’s good to know we can do this in future if we need to.
Thank you for this! Very helpful!
I ran /bin/mount -o rw,exec,remount /var/volatile
then sudo sh installer.sh
to get it to work, and I did not select the legacy packet forwarder in TTN.
Also note that it shows an error, which does not currently seem to matter:
Configuring mp-packet-forwarder.
module.js:340
throw err;
at node.js:945:3
Starting ttn-packet-forwarder: OK
Same issue here after remote firmware upgrade. Your fix cured it. Thanks. It’s not a great management experience if you’ve got a lot of these to look after is it ?
Thanks, @jturello!
I also had this problem, and your solution fixed it!
But I had to add ‘sudo’ before your commands, as I was getting this error:
mount: only root can use “–options” option
