Issue connecting to The Things Stack / LGMD:Rejected packet (0x11)
my TTG was off the past months and I dediced to make it live back on TTN.
I have discovered the recent changes with v3 annoucement.
Maybe I did things wrong but I would like your support:
  • I have removed / deleted the gateway from v2. (actually the gateway was not able to connect)
  • I have upgrade the gw with beta firmware available, to have it running 1.0.8 version which is a prerequisit. The stable version was 1.0.7
  • Then I have created my gateway on https://eu1.cloud.thethings.network, strictly following the instruction
Unfortunately, the 2nd LED keeps blinking slowly and I have used the UART to get the messages:
Firmware name: AmazingAckermann, type: 0, version: 1.0.8, commit: 846da98b, timestamp: 1574945235
Bootloader revision: 2, commit: c463e87e, timestamp: 1519396960
Build time: Nov 28 2019 12:48:18
Reboot reason: 0x40
BOOT: (persisted info) 6F 72 72 65 01 03 6D 9F 0C E2 AD 6E C8 59 82 4C
MAIN: Leaving state 0
MAIN: Entering state 1
FLASH: Magic bytes found: wifi config present
FLASH: Magic bytes found: activation data present
FLASH: Magic bytes not found: no stored FOTA data present
FLASH: Loading Firmware Data
CNFG: (Firmware HASH (sha256)) F7 4B 6E FA 9E 91 AE E4 2C 62 8E D2 50 1B 43 3C C0 69 36 41 AA 52 86 F7 67 0F 44 7A 6E FD 25 F2
FLASH: Loading WiFi Data
CNFG: WiFi SSID: GrangeNeuve_2.4Ghz
CNFG: WiFi key: ***
CNFG: WiFi conn_type: 1
CNFG: WiFi sec_type: 4
FLASH: Loading Activation Data
CNFG: Gateway ID: venon-mch-gn
CNFG: Gateway Key: ***
CNFG: Account Server URL: https://eu1.cloud.thethings.network
CNFG: Locked: false
CNFG: Locked first time: true
INET: Connected to a network, waiting for DHCP lease, checking validity with ping
SNTP: State change from 1 to 2
WIFI: IP Address: 192.168.0.110
SNTP: State change from 2 to 6
MON: SYS Stack size: 3965
MON: TCPIP Stack size: 3828
MON: APP Stack size: 7987
MON: LoRa Stack size: 3885
MON: heap usage: 179KB (188KB), free: 160KB
MON: SYS Stack size: 3959
SNTP: State change from 6 to 1
Any help would be greatly appreciated.
@kersing your help would be valuable I think
Just try again some couple weeks after. I am now stuck later in the activation process. Will check and post later if I don’t success to troubleshoot. I think the eu1.cloud server was down the day I try to upgrade to v3
You can’t connect a TTIG to v3 yet. Search the forum.
Hi. Strange the gateway is now connected … and active in my console. It is “the things kickstarter gateway”. I did follow this tutorial: The Things Kickstarter Gateway | The Things Stack for LoRaWAN
Hum, yeah, I keep forgetting to play spot the I, so I read it as TTIG when it is in fact TTG or possibly TTOG.
