Is there any "increase antenna gain" on arduino LMIC sketch?
I’m testing LoRa node range and RSSI with arduino UNO R3 and NiceRF LoRa V2.0 SX1276 915MHz.
I’ve tried to change many antenna such as
  • spring antenna 2.15 dBi gain
  • 6 cm antenna 2 dBi gain
  • 15 cm antenna 3 dBi gain
  • 26 cm antenna 3.5 dBi gain
and the result is make sense, the better and bigger antenna the better range and RSSI.
Now I want to increase its range and RSSI with coding.
So I want to know Is there any “increase antenna gain” on arduino sketch?
P.S. I’m using “ttn-abp” sketch from “ARDUINO IDM LMIC” framework library.
and here is my sketch
 * Copyright (c) 2015 Thomas Telkamp and Matthijs Kooijman
 * Permission is hereby granted, free of charge, to anyone
 * obtaining a copy of this document and accompanying files,
 * to do whatever they want with them without any restriction,
 * including, but not limited to, copying, modification and redistribution.
 * NO WARRANTY OF ANY KIND IS PROVIDED.
 * This example sends a valid LoRaWAN packet with payload "Hello,
 * world!", using frequency and encryption settings matching those of
 * the The Things Network.
 * This uses ABP (Activation-by-personalisation), where a DevAddr and
 * Session keys are preconfigured (unlike OTAA, where a DevEUI and
 * application key is configured, while the DevAddr and session keys are
 * assigned/generated in the over-the-air-activation procedure).
 * Note: LoRaWAN per sub-band duty-cycle limitation is enforced (1% in
 * g1, 0.1% in g2), but not the TTN fair usage policy (which is probably
 * violated by this sketch when left running for longer)!
 * To use this sketch, first register your application and device with
 * the things network, to set or generate a DevAddr, NwkSKey and
 * AppSKey. Each device should have their own unique values for these
 * fields.
 * Do not forget to define the radio type correctly in config.h.
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#include <stdio.h>
//GPS
#include <SoftwareSerial.h>
#include <TinyGPS.h>
SoftwareSerial mySerial(8, 9);
// Module -> Arduino
//     TX -> Pin 8
//     RX -> Pin 9
TinyGPS gps;
void gpsdump(TinyGPS &gps);
void printFloat(double f, int digits = 2);
//GPS
// Count for interval losing
int count = 0;
// LoRaWAN NwkSKey, network session key
// This is the default Semtech key, which is used by the early prototype TTN
// network.
//c30464d6e404847c6b2bdcdfeee3e44a
static const PROGMEM u1_t NWKSKEY[16] = {  };
// LoRaWAN AppSKey, application session key
// network.
//6a997e1488064d3028579ea77942c623
static const u1_t PROGMEM APPSKEY[16] = {  };
// LoRaWAN end-device address (DevAddr)
//07ffa7f7
static const u4_t DEVADDR =  ;
// DISABLE_JOIN is set in config.h, othe rwise the linker will complain).
// assign mydata size
static uint8_t mydata[48];
static osjob_t sendjob;
// cycle limitations).
const unsigned TX_INTERVAL = 1;
// Pin mapping
    .nss = 10,
    .rxtx = LMIC_UNUSED_PIN,
    .rst = 5,
    .dio = {2, 3, LMIC_UNUSED_PIN},
void onEvent (ev_t ev)
    Serial.print(os_getTime());
    Serial.print(": ");
    switch(ev) {
        case EV_SCAN_TIMEOUT:
            break;
        case EV_BEACON_FOUND:
            break;
        case EV_BEACON_MISSED:
            break;
        case EV_BEACON_TRACKED:
            break;
        case EV_JOINING:
            break;
        case EV_JOINED:
            break;
        case EV_RFU1:
            Serial.println(F("EV_RFU1"));
            break;
        case EV_JOIN_FAILED:
            break;
        case EV_REJOIN_FAILED:
            break;
        case EV_TXCOMPLETE:
            if (LMIC.dataLen) {
              Serial.println(LMIC.dataLen);
            // Schedule next transmission
            break;
        case EV_LOST_TSYNC:
            break;
        case EV_RESET:
            break;
        case EV_RXCOMPLETE:
            // data received in ping slot
            break;
        case EV_LINK_DEAD:
            break;
        case EV_LINK_ALIVE:
            break;
         default:
            break;
void do_send(osjob_t* j)
    if (LMIC.opmode & OP_TXRXPEND)
    else
        // GPS
        bool newdata = false;
        unsigned long start = millis();
        while (millis() - start < 5000)
          if (mySerial.available())
            char c = mySerial.read();
            if (gps.encode(c))
              newdata = true;
              break;
        // get Lat/Long
        char tmp_string[64] = "GPS:";
        if (newdata)
          long lat, lon;
          float flat, flon;
          unsigned long age, date, time, chars;
          unsigned short sentences, failed;
          char tmp_char1[15];
          char tmp_char2[15];
          gps.f_get_position(&flat, &flon, &age);
          //Convert float to char*
          dtostrf(flat, 6, 6, tmp_char1);
          dtostrf(flon, 6, 6, tmp_char2);
          strcat(tmp_string, tmp_char1);
          strcat(tmp_string, ",");
          strcat(tmp_string, tmp_char2);
        else
          Serial.println("Cannot receive any GPS data.");
        // GPS
        // count
        count++;
        char tmp_char3[3];
        itoa (count,tmp_char3,10);
        strcat(tmp_string, "|Count:");
        strcat(tmp_string, tmp_char3);
        // count
        // print payload string
        Serial.println(tmp_string);
        //Convert char* to uint8_t
        memcpy (mydata, tmp_string, strlen(tmp_string)+1 );
void setup()
    Serial.begin(9600);
    #ifdef VCC_ENABLE
     For Pinoccio Scout boards
    pinMode(VCC_ENABLE, OUTPUT);
    delay(1000);
    #endif
    // GPS
    mySerial.begin(9600);
    // LMIC init
    os_init();
    LMIC_reset();
    #ifdef PROGMEM
    LMIC_setSession (0x1, DEVADDR, nwkskey, appskey);
    #else
    LMIC_setSession (0x1, DEVADDR, NWKSKEY, APPSKEY);
    #endif
    #if defined(CFG_eu868)
    // Set up the channels used by the Things Network, which corresponds
    // to the defaults of most gateways. Without this, only three base
    // channels from the LoRaWAN specification are used, which certainly
    // works, so it is good for debugging, but can overload those
    // frequencies, so be sure to configure the full frequency range of
    // your network here (unless your network autoconfigures them).
    // Setting up channels should happen after LMIC_setSession, as that
    // configures the minimal channel set.
    // NA-US channels 0-71 are configured automatically
    LMIC_setupChannel(0, 923200000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
    LMIC_setupChannel(1, 923400000, DR_RANGE_MAP(DR_SF12, DR_SF7B), BAND_CENTI);      // g-band
    LMIC_setupChannel(2, 923600000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
    LMIC_setupChannel(3, 923800000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
    LMIC_setupChannel(4, 924000000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
    LMIC_setupChannel(5, 924200000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
    LMIC_setupChannel(6, 924400000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
    LMIC_setupChannel(7, 924600000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
    LMIC_setupChannel(8, 924800000, DR_RANGE_MAP(DR_FSK,  DR_FSK),  BAND_MILLI);      // g2-band
    // TTN defines an additional channel at 869.525Mhz using SF9 for class B
    // devices' ping slots. LMIC does not have an easy way to define set this
    // frequency and support for class B is spotty and untested, so this
    // frequency is not configured here.
    #elif defined(CFG_us915)
    // but only one group of 8 should (a subband) should be active
    // TTN recommends the second sub band, 1 in a zero based count.
    // https://github.com/TheThingsNetwork/gateway-conf/blob/master/US-global_conf.json
    LMIC_selectSubBand(0);
    #endif
    LMIC_setLinkCheckMode(0);
    LMIC.dn2Dr = DR_SF9;
    // Set data rate and transmit power for uplink (note: txpow seems to be ignored by the library)
    LMIC_setDrTxpow(DR_SF7,14);
    // Start job
    do_send(&sendjob);
void loop()
    os_runloop_once();
//GPS
void printFloat(double number, int digits)
  // Handle negative numbers
  if (number < 0.0)
     Serial.print('-');
     number = -number;
  // Round correctly so that print(1.999, 2) prints as "2.00"
  double rounding = 0.5;
  for (uint8_t i=0; i<digits; ++i)
    rounding /= 10.0;
  number += rounding;
  // Extract the integer part of the number and print it
  unsigned long int_part = (unsigned long)number;
  double remainder = number - (double)int_part;
  Serial.print(int_part);
  // Print the decimal point, but only if there are digits beyond
  if (digits > 0)
    Serial.print(".");
  // Extract digits from the remainder one at a time
  while (digits-- > 0)
    remainder *= 10.0;
    int toPrint = int(remainder);
    Serial.print(toPrint);
    remainder -= toPrint;
What are the legal ERP limits in your part of the world ?
