I’ve acidentally deleted 3 gateways using the API and readding them might not be possible. Is there a way to revert this, using the console or the API?
Should be possible to re-add them and reuse their EUI’s - what you cant reuse is the Gateway ID - this is a character string that can be set to your convenience, note same ID cant exist on the same cluster. Dont try to use something too obvious that someone else my have used before you otherwise may get rejected e.g. ‘myttngw’ has good chance of having been used…
I was thinking if there’s a way to restore the gateway? For example, I found the cli gateway restore
command but in order to run it, I need the gateway ID which I’m not sure if I can find it.
