Is there a way now, that all nodes can share their data like ZigBee does
Some time ago, 1 or 2 years, an announce informed that the TTN node will be able to share their datas.
For exemple, if a node can not reach the gateway, it can send its datas through another node.
What’s the satus now? I suppose that option is available?
Could you give me more information about that?
Many thanks
Relay is still in specification stage - the LoRa Alliance website will give you the latest information.
Suppose away, perhaps look at the TTS documentation to see if it’s mentioned!
This would refer to ‘relay’ capability and requires specific configuration and relay nodes not just a peer to peer connection on bog standard nodes. Has been discussed and spec evolved over last approx 5 years but not much out there as yet that I have seen……
