Intermittent Data from my Integration
Its not the time (up or down) that is the problem - its the limit of number of downlinks! (Remember each time GW Tx’s your downlink it is unable to listen to every other node that may be transmitting an uplink - hence the limit for social responsibility.) Must confess I sometime find I have mis-configured a node or power up an off the shelf device only to find it breaches limit, or may deliberately configure as conf mode for short test (<10 Tx/Rx pairs) and get distracted or forget to switch off/change settings - am sure it happens a lot and to many people, but once aware should take immediate steps to correct where practical.
  • At most 10 downlink messages per 24 hours, including the ACKs for confirmed uplinks.
