hi
I have searched a lot to find an integration which can show me rssi and snr value changes
for temperature ane humidity live values I am using thethings speak but for rssi and snr I could find anything
In the short term Cayenne/mydevices works with Cayenne LPP in V2 devices and applications and does a good job of showing both rssi & snr…very useful for development and field testing or to see if a device or gw goes partially deaf…perhaps as a result of close proximity lightning strike! Problem is Cayenne integration has uncertain future with V3 transition, though some are bandaiding around this. Go shout on Cayenne forum that we need ttn V3 integration…they need to do some work
None of them do and all of them.
It’s not part of the headline port, f_cnt & payload but it is in the meta data.
It is shown in both v2 & v3 traffic consoles and if you use MQTT or a WebHook, it is present for each gateway that heard the uplink.
I monitor the RSSI and SNR- values of my TTN V3-canary with MQTTexplorer.
Since today I use Cayenne/myDevices with the TTN V3 webhook. It shows and stores the RSSI- and the SNR-values of my Dragino LHT 65.
thanks for the information.
thanks my issue has been fixed.
