Hi, i’ve been trying today to install the V3 gateway stack, but running into a problem at step 1.
Docker, docker-compose are installed, and i’m using the docker-compose.yml file that is in teh git repo.
Im getting this error. ( debian 9 server )
admin@ip-172-31-30-168:~$ docker-compose pull
ERROR: yaml.scanner.ScannerError: mapping values are not allowed here
in “./docker-compose.yml”, line 529, column 26
So, I’ve bumbled through this… having never used docker before, its a first!
I’ve installed the v3 stack on an Amazon EC2 micro.t2 instance which is running debian version 9. The instructions are mostly good, In the getting started guide, it says to use the provided. docker-compose.yml . I had assumed ( wrongly ) that docker would pull all the files it needs when you use this. that is not the case, you needed to have cloned the github repo first. (doh). Once you’ve done that, then the instructions work as expected.
I’ll submit a pull request with the addition of a single line in the README.md file under prerequisites;
because it was installed in AWS, I did need to consider what network ports are configured for the security groups. The details are usefully in docs/networking.md
While I was able to register a single App, and a device, and point a single gateway to it, Its a bit more ‘raw’ than the public interface ( which is very polished ).
Things i need to work out;
How do you set up the network server so it runs like a service ( like any normal service ) any time it gets rebooted
How to see joins/data etc like you can on the public interface
how to more effectively add/remove devices/apps etc. It seems quite long winded to use the docker-compose commands. I have not figured out how to use the CLI on this.
This is what i did, and the response i got. Since I dont’ have a local browser on the server, i connected to this address using the url https://mypublicip:8885… [ can you modify something so it uses publicly reachable names? ]
admin@ip-172-31-30-168:~/lorawan-stack$ docker-compose exec stack ttn-lw-cli login
INFO Please go to https://localhost:8885/oauth/authorize?client_id=cli&response_type=code
INFO Waiting for your authorization…
INFO Got OAuth access token
The message “Got OAuth access token” was displayed in the web browser, and the on the console of the Server, i get the prompt back.
Whats next? How do i use this CLI? Are the commands for the CLI like the ones suggested like this?
Hi, I was blocked by the login also.
When I run log in command
it will prompt to open the following link to complete the authentication:
WARN No access token present
INFO Waiting for your authorization...
Then I open the link through browser, and input the admin password, nothing happens.
From the server terminal, I can see the following log:
This person is having the same issue as i described in issue 179. The use of the CLI/ the Auth process is not immediatley apparent, unless you know what Oauth is.
I have installed V3 stack on debain 10 server using docker and following official instruction.
With my installation I was able to authenticate user using http://10.0.0.100:1885/ (not locally on server) successfully (I saw response 200 on docker log) but I didn’t gain access to console because I was redirected on http://localhost:1885/console (so on the server).
If I try with browser locally on the server login in was successfully.
I haven’t configure at moment any TLS.
Anyone could support me please understanding why server is redirecting locally response and not using ip address?
The installation went so far without problems but I am not able to login to the online console. As soon as I enter my ID and password I get the following error message:
"code": 3,
"message": "error:pkg/oauth:no_user_id_password_match (incorrect password or user ID)",
"details": [
"namespace": "pkg/oauth",
"name": "no_user_id_password_match",
"message_format": "incorrect password or user ID",
"code": 3
I know that the credentials are correct because I can login to thethingsnetwork without problems.
The output of the Stack-Server itself looks as follow
this was my first attempt. However, if I use the username and password defined in ttn-lw-stack.yml File I’m still not able to login.
EDIT:
Following the guide that I mentioned before https://thethingsstack.io/v3.6.0/guides/getting-started/ I didn’t really create a admin account. They are mentioning at some point that I can register an account (if needed) but this doesn’t seem to work properly. Because when I try to register a new user nothing is happening. Even in the log file no entry is produced.
Since I still had some issue when I was running tttn stack I tried to reinstall the server as described in the previous mentioned documentation. I even used the configuration file as described in the documentation. Unfortunately, I keep getting following error message when running:
docker-compose run --rm stack is-db init
Error Message: Starting ttn_cockroach_1 ... done Starting ttn_redis_1 ... done INFO Connecting to Identity Server database... dial tcp: lookup cockroach on 127.0.0.11:53: no such host
Below the content of my docker-compose.yml file:
Unfortunately I was not able to find out the source of the error. The same configuration files do not lead to this problem in another operating system.
I found I had to put it in the ./config/stack folder that is created when you run the docker-compose up command. I think the volumes part of the .yml file mounts ./config/stack as /config inside the container. Not well documented at all…
