Hi
We have a gateway (RPi 3 + Rising HF Concentrator) setup using the followings guides
https://www.thethingsnetwork.org/docs/gateways/rak831/
Everything works fine, however when we enable ADR on the nodes, the SF starts from the default and gradually goes to SF12 and remains there until next power cycle, at which point the same procedure follows again.
I understand that for the node to change the SF the network server has to communicate this to the node. Leading me to believe that TTN is not sending out this information.
I am on the IN865 band and wanted to confirm if this is perhaps something specific to this band?
Any pointers to help fix this would be of great help. TIA.
