I’m sorry i am late.
I’ve solved the power problem.
Could you let me know what can i do for now?
pi@ttn-gateway:~ $ sudo tail -f /var/log/syslog
Jan 23 08:37:20 ttn-gateway ttn-gateway[313]: INFO: [up] Thread activated for al l servers.
Jan 23 08:37:20 ttn-gateway ttn-gateway[313]: ##### 2020-01-23 05:37:20 GMT #### #
Jan 23 08:37:20 ttn-gateway ttn-gateway[313]: ### [UPSTREAM] ###
Jan 23 08:37:20 ttn-gateway ttn-gateway[313]: # RF packets received by concentra tor: 1
Jan 23 08:37:20 ttn-gateway ttn-gateway[313]: # CRC_OK: 100.00%, CRC_FAIL: 0.00% , NO_CRC: 0.00%
Jan 23 08:37:20 ttn-gateway ttn-gateway[313]: # RF packets forwarded: 1 (26 byte s)
Jan 23 08:37:20 ttn-gateway ttn-gateway[313]: # PUSH_DATA datagrams sent: 2 (490 bytes)
Jan 23 08:37:21 ttn-gateway ttn-gateway[313]: # PUSH_DATA acknowledged: 0.00%
Jan 23 08:37:21 ttn-gateway ttn-gateway[313]: ### [DOWNSTREAM] ###
Jan 23 08:37:21 ttn-gateway ttn-gateway[313]: # PULL_DATA sent: 6 (0.00% acknowl edged)
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: # PULL_RESP(onse) datagrams receiv ed: 0 (0 bytes)
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: # RF packets sent to concentrator: 0 (0 bytes)
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: # TX errors: 0
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: ### [GPS] ###
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: # Invalid gps time reference (age: 1579757840 sec)
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: # Manual GPS coordinates: latitude 10.00000, longitude 20.00000, altitude -1 m
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: ##### END #####
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: ##### 2020-01-23 05:37:50 GMT #### #
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: ### [UPSTREAM] ###
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: # RF packets received by concentra tor: 0
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: # RF packets forwarded: 0 (0 bytes )
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: # PUSH_DATA datagrams sent: 2 (444 bytes)
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: # PUSH_DATA acknowledged: 0.00%
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: ### [DOWNSTREAM] ###
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: # PULL_DATA sent: 6 (0.00% acknowl edged)
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: # Invalid gps time reference (age: 1579757870 sec)
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: ##### 2020-01-23 05:38:20 GMT #### #
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: # RF packets received by concentra tor: 1
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: # CRC_OK: 100.00%, CRC_FAIL: 0.00% , NO_CRC: 0.00%
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: # RF packets forwarded: 1 (26 byte s)
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: # PUSH_DATA datagrams sent: 4 (934 bytes)
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: # Invalid gps time reference (age: 1579757900 sec)
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: ##### 2020-01-23 05:38:50 GMT #### #
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: # Invalid gps time reference (age: 1579757930 sec)
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: ##### 2020-01-23 05:39:20 GMT #### #
Jan 23 08:40:50 ttn-gateway ttn-gateway[313]: # PUSH_DATA datagrams sent: 4 (938 bytes)
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: # PULL_DATA sent: 6 (0.00% acknowl edged)
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: # PULL_RESP(onse) datagrams receiv ed: 0 (0 bytes)
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: # RF packets sent to concentrator: 0 (0 bytes)
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: # TX errors: 0
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: ### [GPS] ###
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: # Invalid gps time reference (age: 1579757960 sec)
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: # Manual GPS coordinates: latitude 10.00000, longitude 20.00000, altitude -1 m
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: ##### END #####
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: ##### 2020-01-23 05:39:50 GMT #### #
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: ### [UPSTREAM] ###
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: # RF packets received by concentra tor: 0
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: # RF packets forwarded: 0 (0 bytes )
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: # PUSH_DATA datagrams sent: 2 (444 bytes)
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: # PUSH_DATA acknowledged: 0.00%
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: ### [DOWNSTREAM] ###
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: # Invalid gps time reference (age: 1579757990 sec)
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: ##### 2020-01-23 05:40:20 GMT #### #
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: # RF packets received by concentra tor: 1
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: # CRC_OK: 100.00%, CRC_FAIL: 0.00% , NO_CRC: 0.00%
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: # RF packets forwarded: 1 (26 byte s)
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: # PUSH_DATA datagrams sent: 4 (936 bytes)
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: # Invalid gps time reference (age: 1579758020 sec)
Jan 23 08:40:51 ttn-gateway ttn-gateway[313]: ##### 2020-01-23 05:40:50 GMT #### #
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: # RF packets sent to concentrator: 0 (0 bytes)
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: # TX errors: 0
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: ### [GPS] ###
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: # Invalid gps time reference (age: 1579758050 sec)
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: # Manual GPS coordinates: latitude 10.00000, longitude 20.00000, altitude -1 m
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: ##### END #####
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: ##### 2020-01-23 05:41:20 GMT #####
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: ### [UPSTREAM] ###
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: # RF packets received by concentrator: 1
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: # CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: # RF packets forwarded: 1 (26 bytes)
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: # PUSH_DATA datagrams sent: 4 (936 bytes)
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: # PUSH_DATA acknowledged: 0.00%
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: ### [DOWNSTREAM] ###
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: # PULL_DATA sent: 6 (0.00% acknowledged)
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: # Invalid gps time reference (age: 1579758080 sec)
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: ##### 2020-01-23 05:41:50 GMT #####
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: # RF packets received by concentrator: 0
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: # RF packets forwarded: 0 (0 bytes)
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: # PUSH_DATA datagrams sent: 2 (444 bytes)
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: # Invalid gps time reference (age: 1579758110 sec)
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: ##### 2020-01-23 05:42:20 GMT #####
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: # Invalid gps time reference (age: 1579758140 sec)
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: ##### 2020-01-23 05:42:50 GMT #####
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: # RF packets received by concentrator: 2
Jan 23 08:44:20 ttn-gateway ttn-gateway[313]: # CRC_OK: 50.00%, CRC_FAIL: 50.00%, NO_CRC: 0.00%
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: # RF packets forwarded: 1 (26 bytes)
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: # PUSH_DATA datagrams sent: 4 (936 bytes)
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: # PUSH_DATA acknowledged: 0.00%
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: ### [DOWNSTREAM] ###
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: # PULL_DATA sent: 6 (0.00% acknowledged)
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: # RF packets sent to concentrator: 0 (0 bytes)
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: # TX errors: 0
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: ### [GPS] ###
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: # Invalid gps time reference (age: 1579758170 sec)
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: # Manual GPS coordinates: latitude 10.00000, longitude 20.00000, altitude -1 m
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: ##### END #####
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: ##### 2020-01-23 05:43:20 GMT #####
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: ### [UPSTREAM] ###
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: # RF packets received by concentrator: 1
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: # CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: # RF packets forwarded: 0 (0 bytes)
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: # PUSH_DATA datagrams sent: 2 (444 bytes)
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: # Invalid gps time reference (age: 1579758200 sec)
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: ##### 2020-01-23 05:43:50 GMT #####
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: # RF packets received by concentrator: 2
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: # CRC_OK: 50.00%, CRC_FAIL: 50.00%, NO_CRC: 0.00%
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: # Invalid gps time reference (age: 1579758230 sec)
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: ##### 2020-01-23 05:44:20 GMT #####
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: # RF packets received by concentrator: 0
Jan 23 08:44:21 ttn-gateway ttn-gateway[313]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
