MulBV
(Mul Bv)
May 16, 2019, 12:25pm
1
according to the http integration documentation it should be sending a “confirmed” key.
It seems like I am only receiving a selection of the listed fields from the documentation.
my array contains the following keys:
app_id
dev_id
hardware_serial
port
counter
payload_raw
metadata: time, frequency, modulation + gateways etc.
downlink_url
However I am not receiving the “confirmed” boolean. Is there something I am doing wrong? I can’t find any configuration anywhere.
I have also checked inside the console, the downlinks are successfully confirmed. The HTTP integration is just not passing this data.
Kind regards,
Mike de Bruijn
UdLoRa
(Ud Lo Ra)
May 16, 2019, 2:21pm
2
I checked in my logs and indeed, when the packet is confirmed, I am receiving the confirmed field (if not, I do not receive it). The only difference I can see is that I am using an encoder, thus I also receive the payload_fields key (it should not matter, but who knows? try to add an encoder).
MulBV
(Mul Bv)
May 19, 2019, 8:34pm
3
Thank you for your response. I have tried this, but unfortunately it did not make a difference. Do you have any other suggestions?
system
(system)
Closed
July 18, 2019, 8:36pm
4
