Http Integration issue
Hi I’m quite new to LoRa and TTN.
I’ve been facing some issues with the Http Integration. Although my node(Comtac Modbus Bridge) is sending data every 10 minutes I receive only 2-3 payloads per day. The REST call from data storage returns 144 payloads for the last 24 hours. The application data in the TTN console shows payloads for every 10 minutes. Are there any known issues related to the Http Integration?
Thanks in advance
Predrag
To rule out your own HTTP Integration;
Add a second HTTP Integration pointing to a basket at https://rbaskets.in/web
and see how much data that WebHook collects
@GIAG What is your region?
Thanks for the reply.
With rbaskets payloads are arriving every 10 minutes.
…Switzerland, I’m using the “ttn-handler-eu” Handler.
But rbaskets is the HTTP integration, and that is fine, right?
Where exactly are you getting too few data?
