I have a HT-M01S 8 channel gateway set up next to an open window within an area with known TTN Lorawan traffic happening and not seeing any packets hit the gateway. I’m also running a node that is transmitting to TTN every 10 mins or so, and has been doing so successfully for the past 1 year, in the same room as the gateway - so I’d at least think I should see something.
The gateway status always reads that its been seen within the last minute or two. I’m using the new TTN console. Gateway status messages are appearing in the Live Data section, but nothing else. The Gateway is set to Australia 915, as is TTN (Australia FSB 2).
Is there something obvious I migth be missing as to why I’m seeing no traffic hitting the gateway in TTN?
Also - which of these would be the default setting for FSB 2?
