I agree. but even worse is, that it’s not worth the hassle of upgrading, because the TTN Node hardware will not run longer after the upgrade. its a total battery drainer POS.
Is this due to the Microchip module, the SparkFun AVR or the whole power management?
I am currently also evaluating the RS1xx sensor node…but this one wants a confirmation for each uplink message…haven’t had time to test their RM1xx modules.
Or which sensor node would you recommend for environmental measurements?
In the ‘Module’ menu select ‘Boot Loader Recover’ and your module should be available. For RN2483 (not A) modules the latest working firmware seems to be 1.0.3. (TTN products use the RN2483)
Isn’t loriot.io expensive to use?
At least for the community version it woul dmean that I can’t use the RS1xx nodes as they require a downlink for sending the RTC data…
I use TTN due to the fact that in our country Swisscom is rather expensive…
I am currently very happy with the Laird RG186 gateway…no outages so far with the TTN setup…
