I would like to get started using TTN, using an Arduino MEGA 2560 and the Adafruit RFM95W Breakout 868 Mhz.
The breakout board is properly connected to the arduino and the sample sketch from Adafruit is running well (however, I do not have a receiver part, so I can only tell that the board is sending).
As specified by the Adafruit tutorial, I am using the RadioHead RH_RF95 library.
I already registered an application and a device, but then I don’t have a clue where to get started connecting to The Things Network.
There is no code yet, I am just trying to get it to work and experiment if it is something I can use.
As I understand now, the RadioHead library is not going to work, so I need to look for another library.
While browsing at the TTN website/forum I see several people mention the LMIC library (for example used in Dragino shield). I studied several sketches and posts, but I still don’t get if that should work and if so, how to get the pin mapping right.
Several hours later I succeeded. The lmic library can be used on the Arduino Mega 2560, but I probably had the pin mapping/wiring wrong. Below you find the details of my setup.
The radio module’s GPIO pins are wired directly to the edge of the board according to adafruit. You need a level shifter for the GPIO pins, because they are not 5V safe. Adafruit considers the GPIO pins as an advanced option, because they personally have no use for them according to them.
