I started the join server independently with the command ttn-lw-stack start js
and then got the following output:
INFO Setting up Join Server
INFO Setting up Device Template Converter
INFO Setting up QR Code Generator
INFO Starting...
WARN No cluster key configured, generated a random one key=<<some random key hidden>>
INFO Listening for connections address=:1884 namespace=grpc protocol=gRPC
INFO Listening for connections address=:8884 namespace=grpc protocol=gRPC/tls
INFO Listening for connections address=:1885 namespace=web protocol=Web
INFO Listening for connections address=:8885 namespace=web protocol=Web/tls
INFO Listening for connections address=:8886 namespace=interop protocol=Interop/tls
So the JS seems to have started just fine, but I am unable to bind my NS and AS to it. I am trying to use different AS and NS that support external join servers like the one provided by TTN Stack. I was trying to bind with JS at port 8886, but not sure if that’s the right one, and also what else I am missing before I can make a successful bind.
Thanks in advance!
