How to use fetch() in payload formatter javascript code?
Is it possible to make network requests in the javascript payload formatter code on TTN console?
I tried using fetch() but got some unknown error.
var fs = require('fs');
import fetch from "node-fetch";
Error:
SyntaxError: SyntaxError: (anonymous): Line 3:1 Unexpected reserved word (and 2 more errors)
If it is possible, what library should I use?
Thanks in advance
The JavaScript runtime for payload formatters does not support modules nor network access for security reasons: JavaScript | The Things Stack for LoRaWAN
You will have to find a simpler approach to implement your encoder/decoder.
