I am facing a big issue trying to upgrade the firmware of the RN2483 from 0.9.5 to 1.0 or greater, however I have spent a lot to time fiddling with the Lora.jar tool given in this tutorial , which is the same that in the official post of TTUNO.
None of those methods seem to work, so I would appreciate any other way to be able to update the firmware. I’ve told to use a PICKIT3 but I don’t know how to connect it to the chipset within the UNO since not all the pins of RN2483 are available without soldering ( which I rather not do).
With that version you have a chance the update will work. Version 5 has a capacitor connected to the RN2483 reset pin which makes it impossible to use PICkit3 to program the module.
Quoting the PICkit3 documentation: Do not use capacitors on MCLR: they will prevent fast transitions of VPP.
Because I am trying to gather as much info as possible to upgrade the device, and since it seems to be scattered around the forum, I ask that much
I did so, I connected Pickit to GND and Pickit reset to the reset in the UNO, I connected as well Vdd from Pickit to the 3.3V in uno, otherwise the Pickit won’t detect that signal and it won’t allow flashing the device.
I reset the UNO using its ICSP connector GND and Vcc
It was powered with usb, I measured the pins and I had 3.3V
After doing all that, connecting TEST0 and TEST1 to the pickit, the device was not loaded at all. I only got Address: 300006 Expected Value: 80 Received Value: 0 error while trying to flash, of course, the flash was not carried out…
I did that as well, I had a “DIY” cable for the RESET,TEST1 and TEST0 pins, having connected Uno reset to GND, but in the ISCP pins, which I assume is the same that the other one rigth?
By the way, is my connection of PGC and PGD correct?
Sounds like you tried the right pins, did you solder the connections or just touch wires to the ‘pins’ of the RN? When touching wires it might take a couple of attempts to get it right. Also, make sure the wires from the PICkit to the RN module do not exceed 6 cm.
Connecting to MPLAB PICkit 3...
Currently loaded firmware on PICkit 3
Firmware Suite Version.....01.44.26
Firmware type..............PIC18F
Target voltage detected
Target Device ID (0x0) is an Invalid Device ID. Please check your connections to the Target Device.
2016-10-07 08:30:52 +0200 - Programming...
Device Erased...
Programming...
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0xffff
configuration memory
EEData memory
User Id Memory
Failed to program device
2016-10-07 08:31:10 +0200 - Programming failed
Pass Count: 1
Have you checked there is no short circuit between the pins? I would at least use a piece of paper to make sure there is no short between the ‘header’ and the RN module. (Fold 1 mm to make sure it ‘protects’ the side of the RN module)
On the picture it looks like the reset line might be shorting to ground.
