Below is the AS923-3 frequency plan. 917.3 and 917.5 are the two default channels set up through TTN. In addition to this,other channels must be set up in the network server and LoRaWAN gateway.
We did try TTN to set up the channels based on AS923-3 frequency plan but ended up in failure beacuse couldn’t find the UI for frequency settings.
