In LoRa you can send 6 packets in the same channel at the same time with high probability of success.
I want to know if two things are possible using a SX1276 IC.
1. Sense a particular channel for ANY ongoing LoRa transmissions using the SX1276 IC
2. Sense a particular channel for a particular SF using the SX1276 IC
I want to do 1 and 2 prior to transmission to avoid possible collisions. I am merely interested to know at least if this is possible or know if I am going along an impossible path. I am conformable with register level programming of the SX IC.
Note: I want to sense using the SX1276 IC itself without using further RF equipment. I.e. I have an Arduino MCU and an SC1276 IC.
To answer that specific question, then if the pre-amble has passed and the packet is in progress, then you cannot detect it as ‘LoRa’.
You could read the RSSI and use that to assume there is a LoRa packet in progress, but that method of detection would only be reliable if the signals were fairly strong.
