Hello
I am a bit afraid because an pilot experience to monitor the bud temperature (spring froze) is starting very soon. I am using the v2 cluster and I noticed is going to shutdown soon.
Is there a date? A delay to migrate?
Actually, I am using one application for two vineyard field, but I would like now to create one application by field, then I will need to create two application. I wonder if it is time to migrate and doing all in v3 cluster.
But my action should not stop my measure (for one day, itâs OK), so itâs bit critial.
Second issue, all of my devises and the gateway are in the fields.
I login to v3 cluster and try to create a new gateway to register the gateway which is in the field.
That action will not give troubles to gateway register in v2 cluster?
The step to register a gateway in v3 cluster is a bit different (it look like)
Following the above image, in v3 cluster, I am not sure what I have to enter in Gateway ID and Gateway EUI fields
a Gateway ID is an unique, human-readable identifier for your gateway
A Gateway EUI is a 64 bit extended unique identifier for your gateway
But in my above image, the Gateway ID contain the EUI 64 bit code
In v3 cluster, I supposed, I should give a gateway ID, as TTIG-1
and in the Gateway EUI field, I should copy the id eui-58�
If now, I want to continue the migration.
- I create two new applications, one for year field
- I create all devises. 7 in the application 1, 5 in the application
- I go to the field, and update the devise software with the key
- Then, I can delete the devise and application in v2 cluster with may a couple of hour with an interruption of service.
For now my concern is to migrate ma TTIG and TTOG, and my personnal gateway gateways
Many thanks for your clarification. I am afraid making a issue now as the projet is running
