How to get the JoinEUI when adding a device
Hi Folks,
I have a docker based v3.9.0 stack up and running (after some grief in trying to use self-signed certs for localhost which docker seems to have a problem with), and about to add a Things Node to it.
To do that I need the JoinEUI, which as I understand it is a property of the Join server rather than the device, so how do I get that value ?
Are there Arduino example sketches for configuring a Things Node to use MAC1.1 ?
Phil
No and there won’t be as MAC 1.1 is not implemented by the Microchip module build into the Things Node that contains the LoRaWAN stack.
Add the device using an older MAC version.
Ok - thanks for the clarification
This topic was automatically closed after 30 days. New replies are no longer allowed.
