How to get LoRa Basics Station Authentication keys
Installing Basic Station with Semtech new SX1302 Corecell HW,
from where do I get the “LoRa Basic Station Authentication key” ?
The documentation may help:
https://www.thethingsindustries.com/docs/gateways/lora-basics-station/
in which there are links to follow.
I’ve edited down your enormous title so it’s less of a post & more of a title.
Hello Nick
this is what I am using and I generated the API-key.
I think the only thing missing is the is the authentication key.
I do not find any hint from where to get it ?
regards Michael
This?
https://www.thethingsindustries.com/docs/gateways/lora-basics-station/lns/#lns-key-file
Hello Nick
so the same key which I use to generate the API.key is used in the TTN GW setting for the MQTT Authentification?
Hallo Nick, get get this response on the consol
16:35:06 Update gateway “updated_at”
16:34:03 Update gateway “lbs_lns_secret”“lbs_lns_secret.value”
16:33:35 Update gateway API key
regards Michael
but on the GW Basic station I get this message???
key usage : Digital Signa2021-07-12 14:37:05.704 [AIO:ERRO] tc contains malformed auth token - expecting: {header: value\r\n}*
what does it mean?? & Which file needs to be corrected and how ?
Have the exactly same problem with ROBUSTEL R1520LG. What is the expecting structure of the client key? Can anyone help please?
