How to experiment with LoRa PHY layer parameters?
Hey everyone, I am trying to test the effects of physical layer parameters on its packet reception performance. I am using The Things Uno board as end node and The Things Indoor Gateway.
I want a general right direction on how to proceed with it, in terms of libraries to use if I want to code in Arduino IDE.
Thanks in advance.
As different code bases have different levels of access to such things, which ones were you thinking of changing in particular?
Hey, thanks for your response.
I want to experiment with spreading factor (SF), coding rate and bandwidth in LoS and nLoS conditions. I have so far figured how to alter the SF using TheThingsNetwork library but I doubt it if I can access bandwidth and coding rate using the same library.
Eh?
You want to re-configure the LoRa physical layer parameters of the Gateway, to see how it affects its packet reception ?
Sounds more like you ought to be doing this on a LoRa point to point setup, not good to experiment with Gateways.
Bad idea to change Gateway settings like that, dont.
no, not with the gateway, i want to configure the parameters at end nodes.
I can help you with the results - you will experience 100% packet loss if you change these as the gateway will not be able to hear you.
As @LoRaTracker says, this would really need P2P which isn’t something we discuss / support on this TTI funded forum for TTN
Plenty of libraries out there that support point to point LoRa setups.
You did say in the first post that you were using a Gateway, and you cannot, for this type of testing.
okay, I had no idea that the gateway will not support this kind of testing.
Thank you for your response. I appreciate it
Got it. Thank you
The TTN fair use policy limits the Gateway to sending 10 packets a day to the nodes, which would make meaningful testing kind of difficult anyway.
Also GW’s on TTN are required to follow the pre-defined frequency plans, channel bandwidth settings and FEC parameters,etc. for correct operation and if not to be disruptive to other users - do not attempt on TTN, thank you!.
